QUOTE(brp986s @ May 28 2008, 10:28 AM)
I'll be putting in a 915/wevo in my -6 soon. Is the added complication of the ohmega gizmo worth it? Porsche dropped the straight arm for some reason, but wevo makes a doo-dad so that you can use the straight-arm for simplicity's sake.
I would keep the Omega spring- especially on a 914. If you remove the spring the complications will be the clutch cable tube. The spring provides assist. On a 911 you could go with backdating without the spring but has a much stouter cable tube system where as the 914 is already taxed.
