QUOTE(mattp @ May 28 2008, 06:58 PM)
its 11 and 12, what do they bolt onto?
there are 3 - 6mm bolts (hex head or cheese head) that attach 11 and 12. there is one bolt that goes into a little ..... boss.... protrusion... thing that sticks out of the case and is tapped for the 6mm. two other bolts fit into tapped captured nuts or threads on the heat exchanger outer covering. there is a difference in one of the 11 or 12 parts between side shifter and tail shifter. for tail shifter, piece covers shift rod, for side shift rod is under the piece (not covered)
