WolfR32
May 29 2008, 10:15 AM
So I have been having what seems to be a cylinder not firing when my 74 2.0 warms up and under load. We thought it was the FI so put Webbers on, but it is still doing it... going for the coil next.
Any thoughts?
Thanks!
rhodyguy
May 29 2008, 10:38 AM
what size of carbs? to include all jetting and venturi sizes. bone stock 2.0 other than induction, dist, and fuel pump? check timing, check valves, check for vaccum leaks. ensure equal carb flow with your synchronometer.
WolfR32
May 29 2008, 10:45 AM
The carbs are 40. But this was happening before I went to carbs… I took it in for a check up after I bought it and that is when the trouble started. I drove it back from San Fran with no problems…
purple
May 29 2008, 10:58 AM
You NEED to put post specifically what's in your carbs, otherwise we cant help you. Also, are your valve adjusted, timing correct, good fuel pressure? Carb float level?
for example:
MAIN:1.30
IDLE: .55
AIR: 200
VENT: 28
That's what my weber 40's are. They do the same thing yours do, pop and crack and backfire.
rhodyguy
May 29 2008, 11:10 AM
and you car should not backfire, sneeze back thru the carbs, whatever. nor should it go on it's nose when you give it the gas.
TheCabinetmaker
May 29 2008, 04:42 PM
QUOTE(WolfR32 @ May 29 2008, 11:45 AM)
Maybe your "check up" guy did something or unplugged something.
Heeltoe914
May 29 2008, 05:02 PM
Check Vavles as well.
rhodyguy
May 29 2008, 05:40 PM
did you keep all of the fuel injection equipment?
Zardozz
May 29 2008, 06:22 PM
I had some backfire/pop-spit issues on my teener and I thought it was a prob with the turbo/carb/jetting. Turned out to be a bad spark plug.
