Wow, you got the rumored Helmet optioned car?
Looks like a Great option if your heater is disconnected.
It is quite a great option. The mongrol's shedded hair puts a nice coating of insulation all throughout the interior.
Have a great time at it. Whats the Plan? Driver, showcar. A/X??
The plan is to sell it once it's finished. I'm just too dang tall to fit in the car w/out the top off and even then it's a squeeze. I'd like to try and drive it once it's running again just to see how smooth it rides, but I don't know if that'll be possible as my knee hits the steering wheel, making it quite challenging to get my foot on the clutch.
So anyway, on to the questions I was talking about yesterday:
Looking at Pic #6 you can see where I have new feul line installed. Well kind of, since right now the tunnel lines are out. I had the tank in it before when I was trying to get it to run; but pulled it back out to do the cleaning. Anyway, I was curious- since I'm going to be replacing the tunnel lines with steel (stainless, as was suggested to me a couple days ago), why wouldn't it be a good idea to route a steel line from the pump to the tunnel line? Just route it in the same direction as the rubber line- from the tunnel, off to the right and curving back around to the pump, leaving it short a few inches to allow a rubber line to run from the pump to the hard line (for ease of changing the pump.) Seems to me it's a good idea to prevent kinking in the line. Has anyone done this and what would be disadvantages?
Then look at Pic #8- what's a good way to go about fixing spotty rust like that? If you look at Pic #7 and see the areas I've sandblasted, that's what the rust damage is like in all those areas. I know by rights I should just get a replacement trunk pan, but I don't see why patch work can't be done instead. I was thinking of tacking sheet metal to the underside of the pan, and then using seam sealer or equivalent to fill it in. I'm pretty sure bondo doesn't adhere to rust; and I wouldn't want to use that anyway. Any suggestions?
And finally, pics #4 and #5 of the hell hole. I was looking at the left side engine shelf, and I noticed there was a plastic plug in a hole in that side; but that it wasn't in the bottom but offset to the right on the slope of the metal. (Prolly shoulda gotten a shot of this so we could compare, haha.) Is that a drain hole, and if so, is there supposed to be one on the right side as well? Seems to me that there should be drain holes in these areas, because it doesn't matter how well you seal something up, water is bound to find its way in there one way or another.
That's all I've got for now. Thanks in advance for the advice.
