levonfarra
May 29 2008, 06:23 PM
as topic states.
thanks,
Levon
Rand
May 29 2008, 06:25 PM
Personally, I'm glad to have that moisture trap gone.
Elliot Cannon
May 29 2008, 07:00 PM
Take it off and throw it away. Clean up the firewall and stick some dynamat on it. Make sure there are no air bubbles under the dynamat, or anywhere else moisture can collect.
PeeGreen 914
May 29 2008, 07:47 PM
Just take it off. It's a waste of space.
So.Cal.914
May 29 2008, 09:16 PM
I have seen them use a thin sprayable contact cement.
mattp
May 30 2008, 09:42 AM
how loud/ hot does it get in the passenger compartment without the pad?
dr914@autoatlanta.com
May 30 2008, 10:08 AM
We use the 3-m trim adhesive in the can.
By the way we contracted with Dyna-Mat and have in stock a factory look insulator pad that will pass the concours muster yet not absorb water. Works perfectly absorbs the noise leaves the great sound of a 914!
cobra94563
May 30 2008, 10:10 AM
For the pad on the inside of the firewall...
I used the brush-on contact cement, (like wise for the carpet on the longs.) Similar to the spray adhesive, only thicker.
I thought about using dynamat, but the original was available, is nicely fitted to the contours and fairly heavy, so I thought it would serve it's function.
I didn't think about moisture - moisture should not accumulate unless you have leak that needs to be fixed...
