I'm getting ready to build Mike's engine so I tried bead blasting the engine case. For an experiment I hot tanked two cases, blasted one, then washed them both 3 times with soap & water and blew out the oil passages with 100psi air.
From now on I pull all plugs, tap for NPT plugs and clean.
BTW the blasted case looks brand new.
