wannateener
Jun 2 2008, 05:36 PM
im putting everything in and forgot to draw a pic of what wire goes where on my brake light switch can somebody help please with picture or something
thanks again
dylan
SLITS
Jun 2 2008, 06:40 PM
1971 shows Black w/yellow to terminal 54 .... Black w/ yellow again from Fuse #9 and joined with Grey w/ red to the other terminal.
1973 adds a Red w/ white to the unmarked terminal with the B/Y & G/R.
904svo
Jun 2 2008, 06:42 PM
If you mean the switch on the pedal ass'y the two wires can go either way.
they are brown (ground) and brown/white (switched ground).
wannateener
Jun 2 2008, 07:36 PM
ok thats what i thought right after i posted cause its just on off switch . now i have another question lol. well i have a lot of wires coming out of a circle hole by the fire wall inside the car and i know one is for the cargo light and remembering off the other 914 i dont think there should be alot of wires there they look like they plug into a board and its coming out inbetween the seats
SLITS
Jun 2 2008, 07:39 PM
What freakin' year car ..............?
The main harness goes between the seats on all the cars. On '73 and later there are multiple wires with connectors that plug into the center console harness to run the gauges and clock.
wannateener
here it is sorry its a 74
wannateener
Jun 2 2008, 07:47 PM
me
wannateener
Jun 2 2008, 07:48 PM
QUOTE(SLITS @ Jun 2 2008, 06:39 PM)
o and it was just the switch i got the answer thanks again and i just need help with these wires
Mavrick272
Jun 3 2008, 12:26 PM
What a coincidence!
I am in the same predicament
I have a '74 and I just got a brake light switch and am attempting to install it
So is it the same as on the '71 as listed above?
So.Cal.914
Jun 3 2008, 01:11 PM
Hard to see for me but it looks like the seatbelt / ignition switch cut off relay.
Edit: Splice large yellow wire together and bypass the relay. Others may know more.
