QUOTE(yeahmag @ Jun 3 2008, 02:51 PM)
I cleaned the entire board with electronics cleaner, but it seems to be very weak. I'll try roughing up the inside of the bore a touch with a dremel and a sanding drum. Who knows with this epoxy, it dried hard, but I've heard you complaint from more than one person.
I like the idea of a stand off too... Is that a standard hardware store item?
Try Lowe's.
They have a specialty section in the hardware isle.
Lots of cool stuff in blue drawers.
You might look at using a binder/screw post.
It looks like a flat top screw but it is hollow and the threads
are on the inside.
There is a part that is like this (different name, I can't remember) but
it is used on wood. It has the hole all the way through it so you could
slip it inside the boss opening with the flat top sitting on top of the plastic boss.
If you get the one for wood, you might have to cut or file off the spike that
sticks into the wood. If possible you might want to keep them as they
will keep the post from spinning/turning. If you keep them you will have to
drill or notch the boss for the spikes.
here is a link to a picture of what I'm talking about.
ScrewPost.comSorry I don't have a photo of the wood version.
I have purchased these and the wood version at Lowe's.
You should be able to find something that will work.
--- bill
