Ever use the factory tow hook to haul a 914 rear first onto a tow truck?
Are they ok to use like this?
Where else could a cable be attached from the rear of the car and not do damage?
Ferg
Jun 4 2008, 03:10 PM
I would not use the tow hook. I've owned two cars with them pulled out...
Strap around the lower shock to trailing arm point.
Ferg
URY914
Jun 4 2008, 03:13 PM
Agree with Ferg. Never use the stock rear tow hook to pull your car. I don't why they ever had these things on the cars.
Wrap a strap around the shock at the trailing arm.
TravisNeff
Jun 4 2008, 03:53 PM
Better be sure that trunk latch pin is holding well when towing backwards, ask me how I know.
jd74914
Jun 4 2008, 03:57 PM
I have used it to hold a line for winching and have been fine. All times were onto a flatbed trailor (not a tow truck which is much higher), but hasn't broken yet.
URY914
Jun 4 2008, 06:50 PM
...yet.
dw914er
Jun 4 2008, 07:02 PM
i used it once to strap down the car on a flatbead trailer. Didn't work well. (learned by doing that that hook isn't very useful)
stateofidleness
Jun 4 2008, 08:05 PM
i thought towing it backwards was a bad idea? tops blowin off and windshields blown out etc... myth or fact?
So.Cal.914
Jun 4 2008, 08:37 PM
QUOTE(stateofidleness @ Jun 4 2008, 07:05 PM)
I have heard that too, the top, more than once
Oh sure no problem, just let me come by with my video camara...u-tube
sean_v8_914
Jun 4 2008, 09:09 PM
it is not a myth!!! rear trunk, flying targas and windshields
LowGT
Jun 4 2008, 09:28 PM
<---- Bought a 914 with missing targa top because previous owner towed it backwards.
Krieger
Jun 4 2008, 09:38 PM
I cut mine off track car and welded some on trailing arms
jimtab
Jun 4 2008, 11:44 PM
Jeff, is this for the "multi-colored car"? Might be ok if you had some Pushing on the other enD.
Wilhelm
Jun 5 2008, 01:12 AM
I made the mistake of using the rear tow hook to pull a car into the upper level of a ocean cargo container that I had double decked for storage of 914s. I was using a tractor to pull back on a cable attached to a cable that ran through a block in the back of the container. The rear toe hook broke off when the car was at the top of the ramp. The car rolled down the ramp into the tractor and only destroyed both fenders, the hood and the front of the trunk. I sure felt like a damn dummy. My current project will have loops welded onto the trailing arms not only for towing, but also for tying down.
