Hi guys!
I am writing here because I know that your wide experience may solve this problem:
I have some troubles with the ignition of my car,
at the minimum the engine runs good, and if i give some gas the car starts to "jump", and then if I open all the gas the engine works fine.
I checked the plugs and I found the two in the front very dirty, then I replace them, but after 50km they turns dirty again... just the two in the fron, the other two are fine.
I try to play a bit with the air sensor under the air filter, and with the screw on my ecu (its an european version), but no changes...
what I should check?
grazie,
ciao,
zeno
