QUOTE(6freak @ Jun 6 2008, 12:18 PM)
[maybe.
..I just remember haveing to open the butterflys to see if fuel was being dumped ??i look around and see what i find anyway if your off the accelerater pump your not useing fuel except to idle wouldnt that be on the idle jets .hell maybe im all f`d up.but if it did it like you say the motor would never make it to an idle because it just keeps dump`n gas in to itself?.so just to set it strait FI is better but i have carbs so its a must to rib you fellas with FI
.......ps i love sleep`n outside
When you opened the butterflys to see fuel squirt, you saw: 1.) the accelerator pump shooting gas thru the spray bar ... ask yourself why would this happen. 2.) You would have also seen the transition ports or main jets dumping fuel becuase the venturi created a lo pressure area (otherwise kinda known as a partial vacuum) to suck fuel outta the ports.
If the engine is off ... there is no vacuum created ... nuthin's suckin'. Once you start turning the engine over (at starter rotational speed), there are valves opening and closing and pistons moving back and forth creating suction trying to fill the cylinder with air. The idle port is below the closed butterfly and this wonderous suction is SUCKING fuel from the idle circuit port. If it didn't you wouldn't have the bang that make shit go.
When traveling at a high rate of tilt and closing the throttle, the ports above the butterfly kinda cease to flow fuel 'cause their ain't no vacuum or lo pressure area. The port below the butterfly will see very high vacuum and yes, fuel will come out of the idle port, but it's small so you don't get gallons ... you get thimble fulls. As the engine speed bleeds off, so does the amount of vacuum and fuel returns to the normal idle rate of flow.
Lastly, when you turn the key off, there is nothing to make the gas go bang and keep the engine spinning (unless you have carbon buildup that's glowing red which causes the engine to "diesel").
Return Grasshopper to an entity called a Library ... you know the place while you were in school to go meet your GF de' jour instead of studying ... get books and READ.
After you have read sufficient material, you will come to understand the forces in nature that make your car run. Then and only then can you come back here and put forth really inane theories that can be shot down with a spit wad.
