Full Version: The Project Anklebiter Build Thread.
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33
plymouth37
IT'S ALIVE!!!!!!!
https://www.youtube.com/watch?v=4GiV_jFGDxI
It was a bad coil wire connection!
914forme
Also thank you for the tip on the AN fittings
The -8 is located here, LATEST RAGE 201209-8 You just change the -6 or -8 depending on what you want or wish to use.
Spoke
Awesome build! Can't wait to see it buzzing around.
plymouth37
I sanded and painted the dash.
Now that I have a running engine I need gauges to keep an eye on it!
plymouth37
All nice and clean!
I will probably get a gauge upgrade once I start focusing more on the interior, these will work for now!
Krieger
piratenanner.gif Congratulations on the first firing! That thing sounds good!
plymouth37
I broke out the flaring tool and bender, time to finish the brake system!
I made and fitted the missing firewall lines.
They connect to the rear lines at the separation point near the firewall, lot of systems bundled here, that radiator hose may need some insulation.
I filled up the system with brake fluid, bled the system, brakes are done!
KELTY360
QUOTE(plymouth37 @ Aug 26 2017, 03:54 PM) *
IT'S ALIVE!!!!!!!
BADASS!!!!
Cairo94507
plymouth37
Time to tackle controls! I broke out the torch and bent up a shifter.
I used a 1/4" rod as a template, then bent the shifter rod to match.
Mocked up the splined ends, the ends are in line with each other, with an engine shaped detour in the middle.
All welded, painted, and ready to install!
Ferg
plymouth37
QUOTE(Ferg @ Aug 31 2017, 03:24 PM) *
Maybe! Put in a nice plaid interior, why not?
plymouth37
Shifter rod is in, I adjusted the shifter and have it dialed in pretty well.
Throttle, clutch, and speedometer cables are in as well.
Still some work to do here but this chassis is pretty darn complete!
Cairo94507
tmckenna
I just read this entire thread, and WOW just WOW. Everything is so well done, the car seems incredible. Ive always dreamed of building a (semi) street legal, tube chassis, LS powered, mid engine car and was looking into the 914 for feasibility. I'm super impressed, hope you made some progress since september. Id love to see some videos of this thing at the track someday, I'm sure it'll be hard to beat considering the power, weight, and suspension setup. Awesome job man keep it up beerchug.gif
2mAn
I dont frequent 914world much anymore, but I still get notifications on this thread and everytime I come back, Im just shocked at the build...
I also watched Leno driving Eric Sheas car last night and the urge is coming back... Luckily I dont have a garage to stuff a 914 into... yet smile.gif
plymouth37
Hey everybody, fear not, I haven't forgot about you or this build. We bought our first house in August and that kind of derailed the car build, but here we go, time to get back to it!
Now that the car is reliably running it is time to tear into the WRX engine wiring harness, This may look pretty tidy but in reality there is about 10 extra feet of harness wrapped around in here, time to get out the wire cutters and shorten it to fit!
I started with the brown main plug in the engine harness, this holds the power and trigger wires for the injectors and coils, as well as a series of ground wires from the ecu. I shortened it by about 10' and soldered and shrink wrapped the connections.
I wanted to wait to do this until the engine ran so i could start up the engine and check the codes as I modified the harness be able to catch a problem as i did it rather than after cutting literally every wire that controls the engine. I finished the Brown plug, it fired up well, no extra codes, here is how much extra wire I am dealing with here. Next I shortened the black plug's wires, these hold the sensor leads and grounds. There is an extra gray plug as well that has the cam and crank sensor wires that I merged into unused spots in the black plug so now I only have 2 main plugs leading to the engine.
I also removed the stock WRX fuel and ignition relays and replaced them with a new relay panel I fabbed up. These power the two main ignition circuits for the engine as well as the fuel pump.
Here is a view of how it is shaping up from the top.
plymouth37
Here you can see the 2 main plugs and the wires waiting to be spliced.
It is starting to look manageable!
And here is the final product, looks a heck of a lot better, I think the car runs better too. Best part was actually taking the time to understand how this system works, i didn't blindly cut and splice, I got a wiring diagram and figured it out which was really rewarding, this was one of the last big chunks of the car i really didn't understand or want to mess with.
Next I will fab up a cover and wrap everything up for real.
Here is a side view, boy do i have room for a few extra cylinders in there or what?
Well I think that brings an end to the cleaning and modifying of the entire cars harness, I added my newly culled wires to the pile, I have cut so much wire out of this thing!
effutuo101
Nice!
Cairo94507
EdwardBlume
Charlesforfun
wow. just. wow. I just finished taking my engine out for the first time, have to replace some piston rings. It took me just about an entire weekend just to get the type 4 out of there. sad.gif
Mueller
Impressive work as always on this build.
KELTY360
Congrats on buying a house; no small feat in this market. Are you still in Snoqualmie?
plymouth37
One of the last big tasks I had for the suspension was putting bushings in the rocker arms, previously there was just a 1/2" hole with a bolt through it.
I drilled out a hole in the rocker and welded in a sleeve, then put in the bushings.
These rocker arms are definitely prototypes, I want to drive the car to see what they do, then reevaluate from there, I have a CNC at work, Maybe we mill version 2.0...
I reinstalled the rocker arms, put on the doors and dropped it back down on its wheels.
Now I am going to run it up to temperature and see if anything blows up...
plymouth37
QUOTE(KELTY360 @ Feb 25 2018, 11:43 PM) *
Thanks! We actually bought the house we were renting, no moving, no realtor! Same tiny garage sad.gif
JmuRiz
IPB Image
plymouth37
QUOTE(JmuRiz @ Jun 6 2018, 10:36 AM) *
IPB Image
76-914
PeeGreen 914
QUOTE(plymouth37 @ Jun 6 2018, 09:31 AM) *
Where are you at Dana? Our shop is in Greenwood off of 79th.
plymouth37
QUOTE(PeeGreen 914 @ Jun 6 2018, 01:02 PM) *
I am out in Snoqualmie but I work downtown at 4th and Madison, we should get together sometime, been a while!
plymouth37
Well I started running it up to temperature and then I get a little dribble of coolant coming from the Radiator... oh yeah, like 10 years ago when I last drove this thing it started developing a radiator leak, guess a decade of sitting didn't fix it so I guess i need to pull it.
Now for an activity my 3 year old was all about, leak hunting! Ran a bath, capped the outlets, time for a dunk!
(Look at that tub ring, my wife was about as happy about this as the time I put the intake manifold in the dishwasher...)
Bingo! it was small enough that I had to blow into a coolant hose to build up enough pressure to make it bubble but sure enough here it is!
I got so lucky, literally the easiest spot to access. I mixed up some JB Weld and patched it up.
Reinstalled my freshly washed and patched radiator, I will give it a day or so to dry and see how it holds!
Cairo94507
plymouth37
I am sorting out the rear taillight wiring, looks like another thing I forgot didn't work was the reverse lights. Circuit was good but the switch doesn't engage correctly.
I pulled the switch and the pin was about the right length, I think there is something a bit funky with the switch but I cut a chunk of an allen wrench a little longer than the pin and after a couple filing sessions I got it dialed in.
Reverse light wire gets power when I engage reverse now, one step closer to street legality!
PeeGreen 914
QUOTE(plymouth37 @ Jun 6 2018, 03:28 PM) *
That would be great. There is a number of cool places in the area. Just say when. beerchug.gif
plymouth37
Okay, so a lot of you know the body to this car is still in storage in Wyoming, I am going to retrieve it later this summer, but I think this chassis is ready to start testing now, so I have a plan, a bolt on "bumper" that includes all of the bits to make it "street legal" biggrin.gif I cut up some steel stock using an old license plate as a jig.
Welded it up and used the stock tranny exhaust mounting points to hang it
Then painted it and wired up some led trailer taillights. For fun I mounted the license plate that it ran the last time it drove, tags expired 13 years ago... how time flies!
Well it is about to make its triumphant return to the street! This is going to be fun!
Porschef
10 year Anniversary. Don't time fly indeed...
Cairo94507
plymouth37
QUOTE(Porschef @ Jun 9 2018, 05:32 AM) *
Wow, you are right, 10 years to the day since my first post in this thread, didn't even realize that until you said something, how cool.
Looks like I better take it out for a spin today to celebrate, good thing I just got it insured, titled and licensed! birthday3.gif Anklebiter!
Porschef
Yaay!! Please make/post a vid, I'm sure we'd all appreciate it beerchug.gif
plymouth37
Okay, 10 years to the day, first drive is here, still a long way to go but a major milestone none the less! Thank you to all of you for joining me on the long meandering journey!
As promised here are the videos!
https://www.youtube.com/watch?v=sEqFDY0ZNrk
Got it into third here, tires broke loose at about 4500 rpm in third blink.gif this thing is going to be a monster...
https://www.youtube.com/watch?v=NwWOz25GmaU
horizontally-opposed
This is so far beyond cool that it just made me grin from ear to ear. Congrats!
I also love those taillights...they're subtly "914" with a modern twist. If you can swap the order to have the ambers to the outside, they really would tie in with the car's basis.
Can't wait to see this car as it moves back under bodywork—although seeing all of its systems so low and within wheels is equally fun to look at.
jcambo7
QUOTE(PeeGreen 914 @ Jun 8 2018, 04:27 PM) *
Maybe we could do a PNW get together or something.
type47fan
Finally seeing the car on the road . . . well worth the wait!
TravisNeff
Great to see this on the road again, I love it!
Porschef
Haha, that's great!
Cairo94507
That is just way to cool for words. Congratulations on getting to drive your build. beerchug.gif
KELTY360
QUOTE(plymouth37 @ Jun 9 2018, 10:27 AM) *
plymouth37
QUOTE(KELTY360 @ Jun 9 2018, 03:31 PM) *
Sure does, We should do another Snoqualmie days car show get together this year, I won't even make you push me over there this time! August 19th! We might even let you bring the 911 Jon!
KELTY360
QUOTE(plymouth37 @ Jun 9 2018, 02:43 PM) *
Good idea. I'll be in Portland for a wedding that day but it would be fun for some guys to get together.
Do you have plans yet for how to transport the body?
