Mikey914
Jun 9 2008, 08:39 PM
Well it's official, completed the drawings and have put deposit on the die. will look for these to be available in 35 days. Cost will be $22 (possibly less if I can get enough people that want these.
These are the one that go right at the base of the windshield. I have designed these to be able to install without taking out the windshield. These will be easier to install and remove than the originals.
Let me know who needs these, I'm starting a list.
kconway
Jun 9 2008, 11:29 PM
Me, for 1.
tango-52
Jun 10 2008, 10:22 AM
I'm in for two.
rfuerst911sc
Jun 10 2008, 05:18 PM
I'm down for one.
evan
Jun 12 2008, 05:49 PM
Call me uh, dumb but this for the base of windshield on inside between glass and dash right? How hard to install with out removal of windshield? Does it come with "Installation for Dummy's" cliff notes? I may want one! Let me know.
Evan ( ekatz2@verizon.net )
Mikey914
Jun 13 2008, 12:20 AM
QUOTE(evan @ Jun 12 2008, 04:49 PM)
Yes, this is the one at the base of the windshield. The only hard part is removing the old one as the internal clip was steel and tended to rust to the sheet metal that it attached to. I have had luck using a pick to remove what was left of my seal. the other problem is the old one tends to fall apart.
I will include installation instructions when I get my first article in to show how to remove and install properly.
Thanks,
Mark
flat4
Jun 27 2008, 09:41 PM
How are these progressing? I need one.
Cheers, Steve
Mikey914
Jun 28 2008, 01:45 AM
These are still in progress. The tolerance on the clip portion was too tight on the die an we blew out the die. Currently re-tooling. Trying to have another die up to get first article next week. With the holiday it may stretch out to the following week. These will be available the following week. I'm trying to get these together to take to Issaquah for the soggy side of nowhere meet.
evan
Jun 29 2008, 03:29 PM
QUOTE(Mikey914 @ Jun 12 2008, 10:20 PM)
Thanks,
Mark
Keep me posted on the cost, instructions, and progress.
thanks
evan
Mikey914
Jun 30 2008, 01:27 AM
QUOTE(evan @ Jun 29 2008, 02:29 PM)
Thanks,
Mark
thanks
evan
Will do, blew out that first die, trying to get the new revised die on line before the holiday. I will be posting as soon as I get in. This will be very shortly.
Thanks,
Mark
computers4kids
Jul 4 2008, 05:51 PM
QUOTE(Mikey914 @ Jun 28 2008, 12:45 AM)
Hey Mike...
Could you bring a set of the seals that go on the doors (both sides) and a windshield lower seal to WCR2008? My project is stalled until I get the windshield lower seal...I have to install it first before I can install my Ghetty dash.
Thanks,
Mark
Mikey914
Jul 6 2008, 11:22 PM
QUOTE(computers4kids @ Jul 4 2008, 04:51 PM)
Hey Mike...
Thanks,
Mark
I will be there on Saturday, I should be able to have a sample from the production run available. I'm curious as to where these other seals are coming from, if it was a production run, it would appear that more would be available. By the way, pricing will be less than stated for the initial run, check the revised heading.
computers4kids
Jul 7 2008, 04:12 PM
If you have a windshield seal ready on Saturday, I will definitely take it...also, please bring a set of seals that go on the doors for driver and passenger.
Thanks, Mark
As far as the other windshield seals go...not to sure where there coming from, other than Craig now or did have 14 of them from someone.
Mikey914
Jul 7 2008, 09:16 PM
I'll be there with lots of seals on Saturday morning. Just wish I could bring one of my 914s.
Mikey914
Jul 9 2008, 01:28 AM
After blowing out the die, we started from scratch and modified the lower shape where it clips on. We changed the shape slightly. This will ensure that we do not have the die problems we had previously. Unfortunately, this will push the first article into next week, so I will not have for the show.
But, I will be unveiling a new product at the meet.
flat4
Jul 9 2008, 04:23 AM
Put me out of my misery... What is it? Looks like I need one of them as well :-)
Do you do the outer windshield seal as well?
Cheers, Steve
VaccaRabite
Jul 9 2008, 10:14 AM
Outside windshield trim to replace the chrome?
By the way, I need one of the windshield to dash pieces.
Zach
Mikey914
Jul 18 2008, 10:59 PM
The first one has been tested these will ship the 28th or sooner.
Below are pictures of the old seal and the tool we used to remove it. it was quite effective.
I notched the end to mirror the pillar on both ends, making the seal about 1/4" londer than the opening to allow it to compress into the channel.
The problem I ran into was there were some larger beads of caulking for the windshield. I will be taking some more time tomorrow to trim with an exacto knife.
As you can see from the picture the seal has a bulge where the rubber from the windshield interferes with the clearance. I hadn't anticipated there to be this much rubber interfering with the channel. The windshield was installed with a piece of the old seal missing in this area, so it appears that the void allowed the windshield glazing to pool here. The production piece will be made slightly harder to allow it to force it's way into a void if there is windshield rubber in contact with the old seal.
You can also see that my dash "pad" is quite old. I will be replacing it and doing more pictures shortly, I just wanted to check the fit.
Jul 20 2008, 11:46 PM
count me in for two!
Andy
Mikey914
Jul 21 2008, 12:29 AM
QUOTE(SirAndy @ Jul 20 2008, 10:46 PM)
Andy
Done, Here's some more pictures of it installed with the dash pad replaced.
VaccaRabite
Jul 22 2008, 11:25 AM
Do we put this seal in before or after dash replacement? ie, should the dash be in or out of the car for install?
Zach
Jul 22 2008, 12:00 PM
QUOTE(Vacca Rabite @ Jul 22 2008, 09:25 AM)
either way works ...
Andy
Bertus
Jul 23 2008, 10:09 AM
Count me in for one!
Todd Enlund
Jul 26 2008, 12:38 AM
QUOTE(SirAndy @ Jul 22 2008, 10:00 AM)
Andy
I haven't done mine yet, but I just took the old one out... looks like although it could be done either way, dash in would be easier to get the seal seated properly, but give you less room to work.
southernmost914
Jul 30 2008, 05:05 PM
I'm in for one, pm sent.
Steve
kconway
Jul 31 2008, 09:31 PM
QUOTE(kconway @ Jun 9 2008, 09:29 PM)
Me, for 1.
Mark,
Paypal funds forwarded for 1.
Thanks, and keep turning out great products...like the seal between the fresh air box and cowl between the A-pillars for a 74...please.
Kev
dlestep
Aug 19 2008, 08:08 PM
QUOTE(Mikey914 @ Jun 9 2008, 10:39 PM)
Do you have any more of the lower windshield seals, I really would like to purchase one for my 74.
tks
Dave
westo2
Sep 29 2008, 09:46 PM
Any of these still available?
-Weston
Mikey914
Sep 29 2008, 11:35 PM
QUOTE(westo2 @ Sep 29 2008, 08:46 PM)
-Weston
Yes, PM sent
Howie's 914
Oct 11 2008, 09:37 PM
I need a set also.
GaroldShaffer
Oct 13 2008, 10:14 PM
QUOTE(Howie's 914 @ Oct 11 2008, 07:37 PM)
I need a set also.
ditto
loux951
Mar 14 2009, 08:21 PM
Is this seal still available? I need one for my '70 914-4.
Thanks...
Mikey914
Mar 16 2009, 10:53 PM
Yes just pm me with what you want, and your email, I'll send an invoice via paypal.
Thanks.
Mikey914
Jun 6 2010, 12:43 PM
Here's the thread of the removal and installation someone was asking about.
