QUOTE(rdauenhauer @ Jun 12 2008, 01:59 PM)
Mark that looks extensive
Does it *plug* into the main harness or do you have to splice it onto?
what are the color codes or are the diff for diff model yrs?
let me repeat: "connects to the relay board"
on the relay board, there are two fuses towards the front of the car, the connector for the defroster harness in right in front of those, two prongs sticking out of the relay board.
- the wires for the defroster harness are yellow/red and green. yellow/red goes to the left prong, green to the right.
- you'll also need a relay in the relay socket that is the furthest towards the front of the board, also called the " Window Heater Relay".
- the fuse furthest towards the front of the board is for the rear window heater and should be a 8A fuse.
btw. all that info can be found in the haynes manual on page 147, 154 and 161, depending on the year of your car.
the wiring for the defroster harness is the same for all years.
Andy
