chris914
Jun 12 2008, 04:36 PM
I want to remove the spring and adjuster lever so I can paint the base.
What’s the best way to remove the spring and then put it back together later? I’m pretty sure I can get it apart. What’s the procedure or tricks?
SLITS
Jun 12 2008, 07:27 PM
Use a screwdriver to pop the spring off the roll pin .... drive the roll pin out
Or
Actually, paint the whole damn thing unless you're goin' for CW points.
Or
Tape the spring & such off and paint the rest
SGB
Jun 12 2008, 08:58 PM
Ron's right. Clean it and paint it intact. Put it all together and don't look back.
chris914
Jun 13 2008, 02:22 AM
Most paints don’t like galvanized metal.
It ended up coming apart without too much trouble. I pressed the pin most of the way out. Then lifted the spring over the rolled pin. After that I pressed the pin all the way out.
