bernbomb914
Jan 24 2004, 09:42 PM
we pulled the engine on the yellow beauty and found when we pulled the relay box the bottom had been raped. half the black insulation tar has been removed. it is a 1.8 fi and I am replaceing it with a 2270 with webers. do I need to keep this relay box?
my researdh says it is for the FI but I dont know if it has other functions.
Bernie
Qarl
Jan 24 2004, 09:45 PM
It has the voltage regulator, the fuses for the heater fan blower, the rear window defroster (if you have it), and something else...
Aaron Cox
Jan 24 2004, 09:46 PM
im running webers and i kept the box....controls other stuff than FI too
peel all the tar off, and pot it with RTV black silicone.
Jan 24 2004, 10:01 PM
runs the puel pump too ...
bernbomb914
Jan 24 2004, 10:10 PM
Is there a way to test it to make sure that it is working correctly?
Bernie
Aaron Cox
Jan 24 2004, 10:18 PM
trial and error?
, ask DD, im sure he knows, being the electrical guru
sj914
Jan 24 2004, 11:50 PM
The relay board is just a board that has contacts like a pcb. Just take a a multimeter and the haynes manual and check for continuity. If your just running webers, you can delete the board and rewire for the fuel pump, heater blower and starter.
McMark
Jan 25 2004, 12:40 AM
Don't forget the Tach and coil 12v is in that bunch as well.
Leave it there.
sj914
Jan 25 2004, 12:46 AM
Okay leave it then. But if your really serious about taking it out, you'll have to run separate wiring for those things. Especially if it uses a relay or fuse.
bernbomb914
Jan 25 2004, 01:05 AM
Thanks for the info I will clean it up and keep it where it belongs
Bernie
Dave_Darling
Jan 25 2004, 01:27 PM
You can indeed get rid of it, but you have to connect all of the wires of the various harnesses that hook up to it to each other correctly. You will also need to mount the voltage regulator correctly and hook it up into the alternator warning light circuit. And mount relays for the heater blower fan (if you have one) and for the fuel pump (strongly recommended).
Easier to keep the board.
--DD
