bangingears
Jun 18 2008, 11:45 PM
So.... I am collecting more parts, looking at more cars, and So... this is my plan
C/0's at all 4 corners
upgrade the brakes
Build my own cage
(NOTE: this is when I run into some problems, I would like to build a 4 point (cab) cage that hugs the targa as close as possible, but then tie it into a rear cage which will tie into the rear strut towers and then continue to tie into the "transmission Horn" area.... i figure with a cage like that, MOST of the chassis will be rigid, I will also be using inner and outer counsel plating.)
The best thing about this car, is it will be my DD.... cant wait to start the build
ChrisFoley
Jun 19 2008, 08:22 AM
QUOTE(bangingears @ Jun 19 2008, 01:45 AM)
Build my own cage
How about a kit? I'm currently building one for Jeff Hailpern, with a couple pics on his "Bringing out the Dead" thread.
My Rollcage WebpageI have more pictures as well.
bangingears
Jun 20 2008, 12:16 AM
but i cannot use the targa top correct? i want to retain it.
byndbad914
Jun 20 2008, 12:25 AM
you will still be able to use the top with the bar above the rear targa. Look inside your car and you will see the targa pad and top engage on one plane and the roof then juts upward a bit.
Here is my cage for instance
Click to view attachmentand the top fits without issue
ChrisFoley
Jun 20 2008, 10:39 AM
QUOTE(bangingears @ Jun 20 2008, 02:16 AM)
There is no interference, as byndbad914 stated above.
moggy
Jul 7 2008, 03:40 PM
