[quote name='nycchef' date='Jun 22 2008, 05:44 PM' post='1048095']
What year are we talking about? Is it a stock steering wheel or a modern replacement? Got any pics? I've been into my steering stalk numerous times, so the more info, the better I may be able to help.
Eric
[/quote]
73 1.7 most of it i think here's pics
[/quote]
OK - I know what's up. I did the same thing. You used a screw to secure the horn wire to the metal ring (the Horn Base Plate). It probably goes through the Base Plate and touches the Steering Wheel Center. The problem is that the Horn Base Plate must be held off from the steering wheel center by those little spacers, and cannot touch the steering wheel center (except when you want the horn to sound). If the wire, or the Horn Base Plate has a short to the steering wheel center, the horn should always sound.
Get rid of the screw, and either replace the Horn Base Plate (which is number 6 in the picture) or do as I did, and cut back a small tab from the metal on the Horn Base Plate. Use a female spade connector to attach the wire to the Horn Base Plate.
You must ensure there is no continuiety between the Horn Base Plate and the Steering Wheel Center. The spacers in your picture are one-part of a two-part spacer, which ensure there is no continuiety between these two parts. If you don't have both pieces of the spacers, you probably will not be able to ensure electrical seperation between the Horn Base Plate and the Steering Wheel Center. Additionally, the wire you have attached comes from the Horn Contact Plate (number 2 in the picture). If this plate is worn, you may need to replace it to ensure the horn works consistantly.
The item that only allows the horn to sound when the side of the Steering Wheeel Center is pressed is item number 1, the Horn Boot. This keeps the Steering Wheel Center off the Horn Plate. So you need to ensure all these items are installed correctly, with no electrical shorts between them, to ensure your horn will work correctly.
Hope this helps.
Eric Read
