i read somewhere that early front calipers can be used on rear as a direct bolt in and that late front calipers can be used but offset needs to be corrected - and that with either option one would lose emergency/parking brake.
what happens to the front/rear brake bias with this set up? is it changed much and does the stock proportioning valve need to be replaced with a manual PV?
jim
