First wanted to say you guys are awesome. Got my first 914 a couple weeks ago and this forum has help me resolve many issues already just by searching and reading.
I have a '73 2.0 in good condition. Has been sitting for a year and I'm slowly getting the bugs worked out, using as a daily driver.
Click to view attachment Click to view attachment Click to view attachment
Hoping to get some help on a vibration issue I haven't been able to figure out.
When starting out in 1st, no problem. But when I shift up, if I don't let the rpm's wind up a bit I get a shutter/vibration until the r's come up. Ok this would be normal if you were really shifting early causing it to lug too much, but I'm seeing this when I shift around 2k. If I wind it up to 3k+ then it doesn't happen.
Is the flywheel out of balance, clutch need adjusting, mounts? The PO says it has a new clutch, but the flywheel wasn't right and so it had to have more work done. So I'm thinking they still didn't get it right and this is a flywheel balance problem?
Thanks.
