hey all,
working my way through all symptoms of Running Rich. Above sensor is last shot before rebuilt AFM.
Removed old sensor w/o to much trouble by cutting wire and using 13mm deep dish. Problem is the old sensor had a wider set of threads around it to make it fit the stripped out hole in the block. Can this be bought or will my mechanic have to make this go back together?
Another ? would be is it safe to drive. I assume it is. Don't want to be blowing oil out of the hole I have left in block. I don't think that is the case since old sensor was not covered in oil when i took it out.
thanks in advance for thoughts ideas sugestions.
day-um
jkp
