Eric Taylor
Jan 26 2004, 12:33 AM
The fuel pressure regulator has no effect on the pressure. It seams that no matter which way I turn the nut on the regulator there is no effect on the pressure. Did my regulator go bad? Right now it's at 32 LBS which isn't terriable but, I would like to drop it to the propper spec. Any ideas?
Eric
Air_Cooled_Nut
Jan 26 2004, 01:37 AM
Sounds broken. If you can screw it in all the way without it affecting fuel pressure then it's ka-pooy. Engine is idling when you adjust, correct?
Eric Taylor
Jan 26 2004, 06:36 PM
LOL, it's suppost to be idiling when I adjust it? I was always afraid to do that.
I'll try it.
Eric
