Full Version: tire pressure
nycchef
does anyone know the best tire pressure for yokohama 205/55's. for spirited street driving? 73 1.7 stock rims
jimtab
I usually fill to the recommended pressure from the manufacturer and then adjust using the shoe polish method. Put a dab of white shoe polish where the tread meets the side wall, maybe an inch or 2. Then drive it like you stole it and see how much "roll" is indicated by the lack of shoe polish and adjust as necessary...it's an old method...I sure as HELL didn't come up with it......good luck.
ConeDodger
You don't tell us what rubber compound you have. For R rated rubber, I use 28psi on the autocross course for AO38 R's in that size. I would say, 28 to 32 is a general range.
nycchef
QUOTE(ConeDodger @ Jun 29 2008, 05:18 PM) *
i'll check that out.thanks
Krieger
Go with the stock pressures for street use.
