QUOTE(Demick @ Jun 30 2008, 12:19 PM)
Huh? Coax is an RF connector. Can't just pipe in video from RCA connectors. Would need a RF modulator to do that.
Better way is to get a switcher box. Plug lots of RCA or S-video and audio connections into it, and it outputs to a single set of A/V connectors.
I've used this one in the past, and it worked excellent:
Radio Shack A/V switch boxI also
If you have video inputs to the TV, it would be best to keep the signal in that format. If not, time to modulate and send out via coax (FR modulated signal). Again, make sure it modulates on a channel that is not being broadcast locally to avoid interference.
Eric
