I got this out off this months Car Craft,pretty much applies. 10 signs you have a 914
10. Theres a container of Gojo in your bathtub.
9. You wake up earlier on Sat. than you do on workdays.
8.You can't remember your wifes birthday,but at the slightest prompting you can recite you cars ,
bore,stroke,displacement,cam specs,rocker ratio.bearing clearances, valve specs,rod length,journal diameters, bolt torque specs,carb jetting,plug gaps,shift points,comperssion ratio,
7. You pack your spare tool set for a trip to Barbados,and a carb to rebuild on the plane.
6. You lie awake at night thinking of 914 parts.
5. A jury finds you innocent by reason of insanity when you were stopped for doing 120, you were unable to tell right from wrong.
4. You wake up in the middle off the night in a cold sweat screaming " Die Honda"
3. You fire up a engine you rebuilt for the first time and you get aroused.
2. You and your cam break-in sessions are the topic of heated discussion at the local block associstion meetings.
1. You find a dear john letter from your wife on Monday morning dated Fri.
Any or all apply ?????
Dave
