Full Version: Master Cylinder
Mavrick272
Does anyone know if this master cylinder will fit a 1.8 '74?
http://cgi.ebay.com/ebaymotors/73-PORSCHE-...sspagenameZWDVW
thanks
Dr. Roger
QUOTE(Mavrick272 @ Jul 4 2008, 12:48 AM) *
thanks
i believe that is thee one.
New and not rebuilt? The price is right if so.
cross referenced here.
http://www.vertexauto.com/ShowItem/223958%...der%2019mm.aspx
914Sixer
The ad does not say what size MC it is. I am guessing it is 19mm as that was the stock size for 911 or 914-6. This one is probably a China repo of the ATE master cylinder. ATE ones are in the $200 range. Yes, it will fit.
Mavrick272
excellent
thanks, gentlemen
SLITS
I bought two of them ... they should be 19 mm. Look exactly like an ATE with two exceptions .... the reservoir tubing rubbers seem to be a little different and they don't use the washer under the rubbers.
I just pulled theirs' out and replaced them with the ATE setup ... worked fine.
Paid $129 for the first out of Groton and $95 for the second out of a seller in Canada (I think ... both were eBay). They were both drop-shipped from Camarillo, CA. I believe Pelican Parts was considering handling them. Wholesale cost was in the $50 range. Screw ATE.
Check out uroparts.com - their website.
