Jeffs9146
Mar 23 2003, 05:29 PM
My car is lowered as far as the adjuster nut will allow! What do I have to do to get it lower? I am going to assume I need to remove the torsion bar and piviot it one spline! Am I close and how is this done? Thanks for any input ASAP! I am about to open another beer and I want to do this before I get too twisted!!!
Jeff
Mueller
Mar 23 2003, 05:59 PM
You do not have to remove the bar, but you will have to rotate the adjuster a few splines up/down.
I belive the only way to do so is to remove the bolt while no tension is on the adjuster cap.
Jeffs9146
Mar 23 2003, 07:53 PM
Got it done! it was very easy!
Thanks
Jeff
KenH
Mar 24 2003, 10:03 AM
Be sure you still have enough shock travel.
If the car is too low, the travel is very limited and can cause handling problems when cornering.
Also the camber will change, tire wear may become a problem without re-alignment.
Ken
Jeffs9146
Mar 24 2003, 11:41 AM
Thanks for the tips! I do plan on an alignment after I decide on the "ideal" ride hight! The car is still not road ready yet anyway.
Jeff
