QUOTE(dbgriffith75 @ Jul 6 2008, 05:14 PM)
While a wire wheel does eliminate some of the rust, it will not get it all.
It just depends on how much effort you put into it, Rich.
So far I've had good luck getting rid of the surface rust w/ a wire wheel.
So just quit being lazy!
I would honestly disagree.
Pitted rust (look with a magnifying glass or a microscope) cant be cleaned out with a wire brush unless the metal is smooth....
For the surface stuff I dont use a sandbalster cause then I need to spend alot of time sanding afterwards.
I use the 3m srungy pads on a high speed air grinder...those are awesome.
Way way way better than a wire brush...try one you will be addicted.
Home Depot sells them for a lower speed drill....you will love it.
These are specifically for metal prep and dont remove steel..just clean it.
Pitted metal has to many crevaces and holes to get into with anything on a rotary hand held device (I have tried all the cool stuff from 3m and others)
That is why I use a sand blaster.
Eastwood has them, probably harbor frieght also.
I think its called a speed blaster.
http://www.zendextool.com/speedblaster/Rich
