OK, so, after a rather frigid friggin winter here in Germany and a lot of travel, I finally started working on the car again. As noted previously, I got the transmission done thanks to the helpful advice of Herr Evil
So, I began working on the shift linkage assembly to hopefully remove some of the slop; yeah I know, the only way to really get rid of it is to get me a side shifter. Eventually but right now the Tail shifter is what I have to work with.
I looked up some of the threads on PP and began down that road rebuilding the shifter assembly first then moving on to doing some other parts inspections and replacements. I replaced some bushings and balls and, after close inspection and cleaning of the shift rod, had to replace that as well. towards the front of the rod where it mates to the balls on the back of the firewall, there was a rather large 'slice' for lack of a better word that split the rod. It was about 2 inches long and about 3mm wide. Luckily, there is a guy here in Germany who has a lot of used parts that I was able to get a new/used rod from.
After all that was done I began cleaning the engine tin screws. Discovered an interesting phenomenon. If you put the screws into 'rust treatment' solution, a German brand, and forget about it for a week, when you get back, you have what looks like a fossilized rock from a tar pit.
The solution solidified around all the screws! Guess I'll be getting new screws.
So I decided to tackle the re-threading of the heater cables. WHAT A ROYAL PAIN IN THE ASS!!! Not that I wasn't expecting that, as I searched the forum for 'solutions' to get the driver side cable through the bend it was clearly evident that this was not going to be easy. I did it though and got a good layer of grease on the inside of the tubes to keep em moving smoothly.
Time to replace the heater hoses, that was easy, check the flapper boxes, they are ugly but move fine. Still need to wire the heater lever to the control panel but I may actually have heat in the car this winter!
So what do I have left? Well here is my list at the moment.
1. Replace exhaust studs.
2. Install new exhaust gaskets.
3. Fill up transmission with fluid.
4. Finish assembling motor with transmission.
5. Clean up the carbs (they have been sitting so I am pretty sure the gas has crystallized on the needles.)
6. Finish wiring the heater lever to the control box.
7. install the motor.
8. Time the motor.
9. Get it inspected.
At this point I just need her to run reliably without any major exhaust or oil leaks. Once this is done, I can get her registered and then she is ready to ship back stateside next year. I have one more year here in Germany then I head back to the states.
After I put my MG back together, I'll completely tear the 914 down to the frame and start all over again!
But this time it will be a methodical and deliberate process that gets her completely up to snuff. I sometimes wonder if I have taken leave of my senses but then I remember that I re-married and had another kid so the answer is...yes.
