OK, after a slow start this morning, I watched Mongol instead of working on the car, good movie by the way, I headed out to tackle the teener again.
First, lets adjust the shift linkage. Boy what a PITA! Whoever designed the access panel and clamp assembly needs to be shot! Got it done but I am surprised I didn't throw out my back doing the different contortions to get to the bolt and nut on the clamp.
Next, pull the cylinder cover and check torque of nuts. Oh crap, I forgot, If I want to get some of the nuts I gotta take off the tin! Well, lets check the couple I can reach. Yup they were good so I am pretty sure head to cylinder torque is not the problem.
So, lets start her up and take her for a spin, so she's running, so far no oil. Get in, push in the clutch, put her in reverse.....GRIND GRIND GRIND! What the hell? How about 1st? GRIND GRIND GRIND! Well that's not good.
OK, I clearly need to adjust the clutch cable as I obviously didn't get it right when I reinstalled it. So after some checking here and there I found where I screwed up and made the adjustment. Lets try again, OH HONEY! "WHAT?!" Come out here and push the clutch in so I can make sure it is engaging!
Out comes the wife, she gives me the long suffering look, I get under the car, "now?" Yes dear, now. She pushes, still a bit loose; send the wife on her way and make some additional adjustments. This time I clear everything out of the way again, start her up, clutch....put in reverse...WOOHOO!
Back her out of the garage!
Now, lets take her for a little spin shall we?! So I run her about 5 miles, get her up to about 50 and hit some stop and go traffic until I finally get back, about 10 minutes total time. Pull her in, leave her running and check under the car. All I got is an occasional drip with some splatter from the vibration of the motor. I still think she is coming from the #2 cylinder but it is very, very minor.
Well, before I re-attach the warm air guide and connecting tube, I plan to run her into work tomorrow which will be a good 15 mile trip that takes about 30 minutes on the back road. If I am getting just a minor drip then I am not going to worry about it. I'll just keep an eye on it and make sure it doesn't get worse. Should get me through the winter. I do need to make sure the HEs and the defroster work but I'll have to tackle that next weekend as I have a trip to Garmisch this week for a conference. No, not taking the teener, riding the bike down cause I'm a glutton for punishment! Should be a cold ride.
I am due to move in June of next year, she just needs to behave until I get her back to the states, once I get her back and have all my tools out of storage she can act up again. I am sure I'll have questions as I dig into the defroster and heating system, the saga is not over, just on temporary leave.
Time for a beer, especially since I am feeling much better and seem to be getting over the bronchitis.
