Borderline
Jul 5 2008, 11:50 AM
This will be you last chance to do some tuning on the surface used for the Shoot-out. I've been running the tire pressures up front at 20psi and am thinking of trying 18 psi. How low can you go? (Kumho 710's 205-50-15)
DanT
Jul 5 2008, 05:00 PM
wow,, that is low Bill I ran the 710s on the Puttputt at 24psi.
with your aggressive alignment and lots of camber you may get away with running low PSIs without rolling over the outside edge.
might have to come down on the 13th if I can get away.
time to sort out the great white whale a bit more.
grantsfo
Jul 5 2008, 10:13 PM
Lowest I went with 710's was 21 PSI, but why not expereiment? Your car is fairly light.
