QUOTE(Grelber @ Jul 14 2008, 05:24 PM)
Hey Betty, what's wrong with your car?
QUOTE(Rusty @ Jul 14 2008, 05:28 PM)
The mechanic can't reach the engine bay....
QUOTE(Gint @ Jul 14 2008, 09:29 PM)
Step ladder broken?
Buy a shop crane and a bosun's chair for that big ass garage.
Could make for extra fun on Saturday nights.
It all started with me doing maintenence... pushrod tube seals and a valve adjustment... then Dirk Wright showed up in my garage.
I pulled the heat exchangers to get to the pushrod tubes easier. When I put it back together, it had a slight exhaust leak. ( this was about a month ago.....)
So about 2 and 1/2 weeks ago, I pull the heat exchangers to repair the exhaust leak. Putting it back together, it snaps an exhaust stud. Cue the cussing and swearing. I remove that stud and replace it. I go to put it back together and ANOTHER stud snaps off. I try to remove that broken stud, and it breaks again flush with the head.
Now I am really pissed... I pull the motor, and remove the cylinder head so I can take it to Lyle Cherry to get the studs replaced. Had to wait a few days to get the head back. Cue Dirk Wright to enter. Got the head back, and put it back on. So I picked up a gasket set and crank seals. I strip the motor down to the long block to clean it.... god what a mess! Oil everywhere. I find the source of the leak. The fan end crank seal is so brittle that just touching the sealing surface causes it to crack!
So we have spent the last 2 Sundays cleaning the engine tin, the inside of the fan housing, the transmission, etc... In the process of putting it back together, Dirk Wright keeps showing back up. I replaced the alternator that had a noisy bearing, the alternator and AC belts, the positive battery cable, the shift linkage bushings, replaced the speedo drive assembly with a brass speedo drive to prevent future leaks, fixed the cracked mounting flange on the LH heat exchanger, and last but not least, rebuilt the entire fuel injection wiring harness. The one that was on there had major cracking in most of the wires. So I used another harness that someone had cut the air flow meter wiring connector off, and repaired it with bits of the old harness. I also put a new AC idle up solenoid (ok a fuel tank switch valve for a pickup truck), and after the engine was back in the car, cleaned the bottom of the engine to remove all the gunk accumulated from 6 years of driving daily.
Betty spend hours cleaning dirt and oil off the parts, and also off the underside of the chassis. She has cuts on her hands and dirty fingernails. But she is happy that her car is getting the attention it needs.
Gotta love a woman who will help out with something like this.
It is back in and running, but I still need to find out why the AC clutch circuit only shows 9.2 volts, and do things like set the timing and adjust the shift linkage.
Is that enough????
Oh.. and Rusty.. you are one to talk about not being able to reach the engine compartment.... You, my friend, ain't much taller than me!
Gint.. thanks.. Betty kinda likes your idea!!
