QUOTE(kwales @ Jul 15 2008, 08:00 PM)
Piledriver on Shoptalk forums is big on those stainless steel woven pot scrubbers. Apparently the VW guru -Bob Hoover- figured it out that SS pot scrubbers make excellent air/oil separators.
He runs "Chore Boys" brand.
Ken
This is similar to what I was thinking of using. A steel mesh/wool type material. Seems the best option as a fiberous material would soak up the oil rather than just collect it. I don't know that I'd want steel wool tho- that could possibly break up over time and send little pieces back through the intake system, which would be bad.
QUOTE(spunone @ Jul 16 2008, 06:35 PM)
can't you use the stuff they use in racing fuel tanks ?
I don't know what you're talking about...
Okay, so here's some pics of what the current set up looks like.
This is the current breather. I dunno if it's stock or custom, but it's just a rubber elbow coming out of the oil breather base. There's no valve or anything inside it.
Click to view attachmentThis is the placement I'd like to have for the filter. Ideally it would just attach in the same place as this one but I don't know if that will work just yet. It depends on the size of the chamber I need. And the caption in the pic says there or at a 90* angle, but I just realized that won't work. It would have to be a slight angle, no more than a 45* bend, otherwise the oil wouldn't drain back into the case.
Click to view attachmentHere's a side shot of the current air filters. Like I said before, they measure about 6" long by 4" wide by 2" deep.
Click to view attachmentHere's a top shot of the air filter. Per Racer Chris, I would drill a hole inside the circled area to allow the flow directly into the carbs, behind the filter.
Click to view attachmentHere's where the current set up runs to on the intake manifold. I'm going to remove the nipples and plug the holes on the intake, then use the nipples to attach the hose to the top (or bottom) side of the air filters, then use a nut on the other side to secure and stabilize the nipple.
Click to view attachmentThis is a rough blueprint of what my filter is going to look like. Originally I was going to just stuff the filter material into the chamber, but then I wondered about the possibility of the material somehow working its way into the hose and/or the breather base, so I decided that adding a screen of sorts would help hold it in place and prevent that. The chamber and caps will be aluminum conduit fittings. I'll drill and tap the caps to allow for a nipple to be inserted... at least on the top. Depending on if I can get away with mounting it directly to the base or not will depend on how I set up the bottom.
Click to view attachmentSo I guess the only thing to figure out is what size chamber I need. The hose I'm using is 13/16" OD and 1/2" ID. So, Racer Chris, how do I calculate what size chamber I need?
And does anybody have any thoughts/suggestions on what could be done to make this system a little better?
