QUOTE(Dave_Darling @ Jul 22 2008, 12:05 AM)
The 74 only had one turn signal indicator in the tach, just like the 75s and 76es. A few of the early-early 74 had 73 tachs, with two indicator lights in the tach. But they were wired up to the single existing signal wire, so both would flash at the same time.
--DD
The wire I guess is the Blue/white stripe for the single indicator then.
The four way lights & flasher work, but the turn signal switch doesn't make the front & rear lights work nor does the light in the tach. Any idea what that problem is?
