QUOTE(rhodyguy @ Jul 18 2008, 09:55 AM)
just to be sure. you're not trying to remove the bracket portion (3 bolts that go into the case) right? iirc when i intalled the rubber mounts (without removing the fan shroud) i used a box wrench. move the nut securing the mount to the bracket a fraction, repeat, repeat, repeat. get the damn bar out of the way! TOTALLY!
k
Correct, I was not trying to remove the mounting bracket - tring to remove the one 13 mm nut on the top of the engine rubber mount. Well you can only move the engine support bar so much since the spedometer cable(?) and tranny shifter (?) run through the bar. Also, yes the fan housing is a major contributor to the lack of access. It did not look like it would be an easy move.
You actually got a wrench on the nut??
What's the next step, remove the engine / tranny?
Thanks
Dale
