G e o r g e
Jul 17 2008, 10:59 AM
What are you running behind the header?
I have a super trapp and it is just to loud.
what are my options?
Zundfolge
Jul 17 2008, 02:22 PM
You can take a bunch of diffuser disks off the Supertrapp and it'll be a little quieter.
I happen to love annoying my Harley driving neighbors with the loudness (I have 8 disks in mine).
Since its just a pipe (I don't think there's a flange ... I'll have to look) pretty much any muffler will work ... or at least can be made to work.
hydroliftin
Jul 17 2008, 02:32 PM
QUOTE(Zundfolge @ Jul 17 2008, 01:22 PM)
G e o r g e
Jul 17 2008, 02:35 PM
I'm running 12 disks
I'll drop them down to 6
my header has a 3" 3 bolt flange, I was hoping somebody knew of a muffler that could bolt on
I guess i'll have to get 1 made up
Zundfolge
Jul 17 2008, 03:10 PM
Yep, just had to run out to the parking lot to throw the roof on (rain a comin') and looked under the car, there is a flange.
well if you didn't mind destroying the Supertrapp, you could cut the flange off it and weld it to any other muffler.
r_towle
Jul 17 2008, 03:32 PM
Autozone sells hush thrush mufflers. Its an oval muffler.
Its very open, but tones down the 914 nicely.
They dont sell flanges, but a decent muffler shop will sell you a flange, or they will even tig one on your muffler for you.
I had an original (pre Foley) header like foley makes. I got the muffler and flange...welded it up and added a bolt on tail pipe to pass tech/noise inspection..simple.
Rich
ChrisFoley
Jul 17 2008, 05:29 PM
QUOTE(George H. @ Jul 17 2008, 12:59 PM)
I recommend a long pipe (about 36" long) from the flange that makes a turn behind the tranny to a conventional chambered muffler, and a tailpipe on the other end.
G e o r g e
Jul 17 2008, 05:59 PM
QUOTE(Racer Chris @ Jul 17 2008, 04:29 PM)
Chris
Should the 36" pipe be the same size as the collector?
my other option is to install that 1st generation setup I have that you made..
how quiet is this setup?
ChrisFoley
Jul 18 2008, 06:35 AM
If you have that, what are you messing around with the KHH for?
More power, quieter, nicer sound, heat, looks cool, new, more power.
Just the Stage I is as loud as the Supertrapp with no plates. Adding the second stage silencer makes it quite reasonable for the street.
The KHH extension pipe should be 2 1/8" or 2 1/4".
BTW, I can help you update the Tangerine heat exchanger to distribute air to both sides of the cockpit.
G e o r g e
Jul 18 2008, 12:05 PM
That's what i thought you would say
I'll swap it out Sat.
where should i mount my 02 sensor on this , after all 4 have tied together?
right now I wasn't going to run heat, but by using this setup It will probably be a project for the future
jhadler
Jul 18 2008, 12:29 PM
QUOTE(Racer Chris @ Jul 18 2008, 04:35 AM)
Why are you even asking about the KHH if you have that piece of art lying on your floor, and not bolted up to your motor?????
-Josh2
ChrisFoley
Jul 18 2008, 03:56 PM
QUOTE(George H. @ Jul 18 2008, 02:05 PM)
Yes, just after the secondary collector.
The heat exchanger is easily installed as a separate project.
