lmcchesney
Jan 28 2004, 06:26 AM
Does anyone have ranges for Type IV cylinder head flows with customary pocket porting and port matching? I believe is about 200-225CFM at each port. Also, any data on the effect of large valves on the flow rates? Any data on port velocities?
Yes, I know that miminal changes can produce significant changes in flow. However, in reality, there is not a lot of variations in the P/P of these heads.
Thanks,
L. McChesney
DNHunt
Jan 28 2004, 08:05 AM
Check over on
Shop Talk Forums. I remember seeing some of that stuff. A buddy of Jake with the handle Ham is a head guy and seems
real sharp. Somebody over there will have it.
Dave
Jan 28 2004, 10:40 AM
QUOTE(lmcchesney @ Jan 28 2004, 04:26 AM)
i have some of that at home, can post it later tonight ...
Andy
lmcchesney
Jan 28 2004, 01:39 PM
Thanks Dave.
Did a search on Shoptalkforums for author Ham. No results. However, there is some data by others. Seems to suggest 200-230CFM per intake port.
Thanks Andy. I await your posting.
Here's a sampling of our P/P job thus far:
L. McChesney
Still can't seem to post pictures.
Jake Raby
Jan 28 2004, 02:18 PM
Don't worry about the intake..... the exhaust is the BIG issue.
lmcchesney
Jan 28 2004, 03:51 PM
Can you expand on that Jake?
Increased porting of the Exhaust ports?
Use of CF's headers?
Increase exhaust duration?
All of the above?
L. McChesney
r_towle
Jan 28 2004, 03:54 PM
Cant seem to upload spreadsheets....... <_< <_<
Error message telling me no bad boy go away...
So try to decipher this
Intake/Exhaust Diameter 1.88 1.5 47mm+- 37mm+-
Valve lift/diameter L/D 0.05 0.1 0.15 0.2 0.25 0.3
Intake Valve Lift 0.094 0.188 0.282 0.376 0.47 0.564
Exhaust Valve Lift 0.075 0.15 0.225 0.3 0.375 0.45
Test Orifice Flow at 10" pressure 156.3 CFM
Test Flow correction factor 0.98
Flow Range (cfm) 10 18 29 40 59 84 105 140 185
Corrected Range 9.8 17.64 28.4 39.2 57.8 82.3 102.9 137.2 181.3
Test Number 1 2 3 4 5 6 7 8 9 10 11 12
Port I or E Intake Intake Intake Intake Intake Intake Exhaust Exhaust Exhaust Exhaust Exhaust Exhaust
Test Pressure 10 10 10 10 10 10 10 10 10 10 10 10
Valve Lift (in) 0.094 0.188 0.282 0.376 0.47 0.564 0.075 0.15 0.225 0.3 0.375 0.45
Corrected Flow range 39.2 57.8 102.9 102.9 102.9 102.9 28.4 39.2 57.8 57.8 82.3 82.3
Flow meter 0.78 0.95 0.735 0.83 0.875 0.885 0.62 0.805 0.685 0.825 0.665 0.715
Chart CFM (Line 17*Line16) 30.58 54.91 75.63 85.4 90 91.1 17.6 31.6 39.6 47.7 54.7 58.9
Temp Difference 25 25 25 30 35 35 15 30 30 30 30 35
Temp Diff Factor 0.981 0.981 0.981 0.977 0.973 0.973 1.012 102.3 1.023 1.023 1.023 1.027
Corr test CFM 29.9 53.9 74.2 83.4 87.6 88.6 17.8 32.3 40.5 48.8 55.9 60.5
Corr CFM 11.1 19.9 27.5 30.9 32.5 32.8 10.5 19.1 23.9 28.9 33.1 35.8
Potential CFM 13.6 27.3 41 47 50.2 52.3 13.6 27.3 41 54.9 58.5 60.1
% Flow rating 82 73 67 65 65 62 77 70 58 53 57 60
R
r_towle
Jan 28 2004, 03:56 PM
Looks like if you copy all of it and put it in a spread sheet it will make sense...
Sorry, not my board...
XLS files are not permitted...
Bleyseng
Jan 28 2004, 04:16 PM
Do it as a screen shot then we can look at it.
Geoff
r_towle
Jan 28 2004, 04:32 PM
try this
lmcchesney
Jan 28 2004, 07:02 PM
Thanks R_Towle
Am I reading this right. 74mm intake at .564 lift has a corrected flow of 88.6CFM?
Can you provide the amount of head preperation done?
Valves 47 x 37mm
Was the exhaust boss removed?
Is the head port matched to 2.0L or 35mm intake 30mm exhaust?
How much bowl porting done?
Was the intakes cleaned to 60 grit?
Thanks for the informaiton.
L. McChesney
Jake Raby
Jan 29 2004, 10:37 AM
Stock intake ports flow over 200 CFM... Getting over 150 out the exhaust is a chore..
Thats why we use split duration- and alot of it!
The more work you do to the intake- the worse the ratio of intake/ exhaust is.... Most of my heads get no port work on the intake.
Flowbenches are great but they are dealing with air that has not gobne through a burning process already.. They give base line numbers- but don't live by one.
I have not flowed a set of heads in over a year on my bench.
lmcchesney
Jan 29 2004, 12:36 PM
Thanks Jake,
That is what we are thinking. The Intake ports have had the protruding seams smoothed and ports matched only and polished to 60grit smoothness. The exhaust ports have had the work with removal of the boss and opening of the port sides while keeping the short radius smoothed but not changed. The port has also been patched.
Denny McNutt, Autocraft Engines, also believes stock heads flow at 200-225CFM and that is the data we have been using in the simulators. The crux seems to find a cam grind with about Intake dur of 260-265 but have an exhaust dur of 270-275.
By the way, Sean Rupp says hello and is still working on his Type IV.
Thanks again,
L. McChesney(Andrew, Eric and David)
Brett W
Jan 29 2004, 06:16 PM
The last set of heads I did were some 2.0 heads with stock valve sizes 42int 37 exh. I managed to get something like 190 on the intake side and something like 145 on the exhaust side. I wasn't happy with them but they will work well for the application. I figure I could have broken 200 on the intakes with 7mm valves and 150 on the exhaust, but the exhaust will definitley take a bunch of research to help them. I am trying to build a flow bench so I can do that shortly.
lmcchesney
Jan 30 2004, 04:51 AM
Thanks everyone,
I pulled out the data from the Grassroots Motorsports article 8(6): 114 Dec 2001 on the head preperation they done and what the flow results were. Very similar.
Intake flow at .5 went from 175 to 188(+7%) and exhaust at .5 from 129 to 157(+22%) with a final E:I of 84%.
On the desktop dyno with a cam of IVD 262° IVO 12°BTDC IVC 70°ABDC and EVD 275° EVO 70.5°BBDC EVC 24.5 with a seperation of 116° and a timing of -5°.
Any thoughts?
Brent, I found an article on making your own flow bench, using six vacum cleaner motors and pitots for flow measurments. Cost estimates $800 with $600 in vacum cleaner motors. It is, "Flow Bench"
by Michael Doty but I don't remember where it is from. With the images, it is too big for attachment. If you email me, I can attach it to the email.
Thanks,
L. McChesney
lamcchesney@netzero.net
Jake Raby
Jan 30 2004, 09:07 AM
Those intakes are flowing WAY too much! Sounds like a "Typical" head job.....
Don't mean to be negative, but that throws the entire combination so far off that you can never get the engine to respond to tuning measures!
cnavarro
Jan 30 2004, 10:58 AM
There is a past thread where I uploaded a flow chart for my 42 x 38 specials :-) I have back in the office flow numbers for a dozen different head configurations that I can post if you guys want them. Here's the link to the thread:
http://www.914world.com/bbs2/index.php?act...st=0&hl=nickiesCharles Navarro
LN Engineering
http://www.LNengineering.comAircooled Precision Performance
Brett W
Jan 30 2004, 12:00 PM
I have seen the article on the flow bench. Not impressed. If you want to flow weedeater heads that might do the job. If you want to do some serious flow research you need to be testing at a minimum of 28 inches of water. I have a three hp motor with a large cetrifugal blower attached that I am going to use for my basis. I suspect the motor will be a little small. I would like to see a 10 hp motor but I didn't have one laying around.
Check out the bench Smokey used to use. Powered by a 100hp electric motor.
http://www.smokeyyunick.com/ look at the ebay items section.
Jake Raby
Jan 30 2004, 01:39 PM
Is that an implication that I have inferior equipment??
I don't need to "Impress" anyone! Our works speaks for its self- argue with that
Fact is all I use that bench for is to measure the splits between ports, I don't even worry about whole numbers.
I already have 95% of all my head combinations matched to my engine combinations. As far as I'm concerned trying to flow heads for days is a waste of time anyway! it just gives you and IDEA on what to do...(how the hell do you think I designed 32 different split duration cams?)
The only way to prove it- is to build it. Unless someone builds as many engines as we do and make small changes and compare the results you will never know what you head numbers did - if you wasted all that time or not.
In my experience, the flow bench is basically a huge waste of time, just something to advertise with.
If I need a bench, my buddy is the shope Foreman over at Ernie Elliot Inc... They have 3 different benchs and the smallest one has 9 motors, biggest one has 27. It flows enough to test heads that have SEVEN POUNDS of aluminum removed from their ports.... Guess what else they have- a superflow 120 just like mine, and its not collecting dust either!
Hell I wouldn't even have one if I had not TRADED for it! It sat here for a year before I ever plugged it in.
Word of advise- Don't ever doubt me or my work, and we'll get along just fine. If you do doubt me you might just find yourself with an ultimate challenge of proving me wrong- better bring your supper with ya when you take that one on, and be ready for 3 days without sleep just to keep up with me!!
We all have our own ideas, I respect yours, just don't imply that I'm working with junk- That REALLY pisses me off.
Jan 30 2004, 01:51 PM
QUOTE(Jake Raby @ Jan 30 2004, 11:39 AM)
thanks for the laugh
now go back and build engines, LOL
Andy
PS: finally, a pissing match where i'm only a spectator ...
Jeff Bonanno
Jan 30 2004, 01:52 PM
Jake, i was checking out the stf posts and in one you said that there were things you could get in trouble for saying - were you referring to proprietary engine configurations? do you have patents or are they trade secrets? just curious!
Jake Raby
Jan 30 2004, 02:17 PM
Can't really patent an engine combo...
I can get "In trouble" by telling the truth about how some things suck, or how junky they really are...
Most crap you buy is not tested at all-
Bleyseng
Jan 30 2004, 06:12 PM
You can't get in trouble here Jake expressing your opinion! You can get in trouble if you say "Crapworks Motorsports parts are a effin joke"
Most of us know you have built tons of engine combo's so you know what works in real life by trial and error. (finally someone who posts with real data instead of the shit from a computer program)
I still wish you would sell parts like cams combo's, etc that you have made to your specs.
Geoff
Brett W
Jan 30 2004, 09:05 PM
Dammit Jake, If you would have read the post you would have seen that I referred to an "article" about the flowbench using multiple vaccum cleaner motors. I can assure a flow bench is not a big waste of time.
Whether you see the worth in the reasearch gained from it really doesn't matter one bit to me. You have your clientel and I will have mine. They will be two different groups of people with two different sized budgets and requirements. I have no reason to doubt your work and never said I did, so back up.
lmcchesney
Jan 31 2004, 07:18 AM
Thanks Guys,
Sorry Bret, I did not know you enough to realize the sophistication level you already have obtained.
Charles, that is very similar to the flows previously posted. Your intake flows continue to .700 lift reaching the 200's. I thought in most heads, flows tend to plateau at ..35-.400 lift. Are you using .700 lift? the exhaust flows are not as good with about a 6% over stock flow. Did you remove the guide boss?
Jake, I always appreciate your input. Your work DOES speak for itself. I certainly have not spent years designing and building engines. In fact, I am the amateur that has some jealousy of the opportunity you have of designing and testing by its creation. I have and will always have tremendous respect for you and your teams efforts.
However, somewhere the data must be off. The flow data is from Tim Studdard's Grassroots Motorsports 914 project (GRM 18(6):114-120;12/01) and Dyno is from (GRM 19(1):87-92; 2/02) which is a near stock 2.0L with Web Cam 73 grind. His post yesterday
http://forums.pelicanparts.com/showthread....threadid=146327, seems to show the combination works. Where do you think the difference is?
Geoff, you continue to be a mentor for our project and steadfast source of realistic information. I agree, computer programs do not produce engine results, as I have discussed with DD. I believe I use the program to help me think how the components interact.
RobotVac, First Amendment rights were created by those with the strength to use them for the benefit of all and defend them. However, its use requires responsibility for their use and results. Are you being responsible?
God's Blessings,
Bleyseng
Jan 31 2004, 08:56 AM
Hi Andrew, Eric and Dave,
The problem I see with your project is that you want to build a higher hp motor for racing but still keep it streetable and use Djet FI. Lots of people have tried this to some degree in the past.
Street driving likes motors that are torquey and can pull the car away from stop sign, stop lights etc. and stay cool for hours of driving.
AX driving likes a motor that is torquey and can pull a car out of slowing down but still rev quickly. Cooling is not that big and issue as the runs are only for 60 secs.
Tracking likes a motor that revs higher and produces is hp up high for high speed blasts like down a straight away but still needs to cool as laps can last 30 minutes.
Its an interesting problem that most before have just gone to carbs or a different FI.
Geoff
DNHunt
Jan 31 2004, 09:37 AM
Geoff
Can you tweak the D-jet to give enough fuel at WOT. I know the stock cam falls off about 5k and the exhaust is a bottleneck so it's not a problem on the street. But on the track with more displacement, better flow, more cam and a freer flowing exhaust, they'll be pumping a lot more air. Can they provide enough fuel?
I hope I'm wrong but, it's sure getting hot in here.
Dave
lmcchesney
Jan 31 2004, 11:26 AM
Dave,
D-jet article says that the 2.0L injector can flow 380cc/min.
I believe the 2.0L engine uses 312cc/min at WOT.
L. McChesney
Bleyseng
Jan 31 2004, 12:52 PM
Depends on the MPS, but I easily had a A/F mix in the 12 to 1 range at WOT from 2000 to 5000 rpms. I had to adjust it to 12.5 to 1 for about the right mix.
There are other problems that can play into a lean A/F mix on these cars. Old fuel pumps, clogged fuel filters, clogged tank inlet screen, and wrong MPS or mis-matched Djet parts.
Just as you Dave had to to assemble everything to get it running with the Megasquirt, you had to go to get it dyno'd to set the fuel MAPS. Everybody should have their cars tuned/checked for the right A/F mix. ( this includes the carb guys)
95% of the Djet cars that get brought to me to check out are running lean, way too lean. The other 5% have a problem like a injector is unplugged(ChrisReale)
Not only does the stock cam fall off but so do the valve springs! The heavy stock valve train can keep up with the revs. Damn I wish I could afford those ceramic lifters!
Geoff
Brett W
Jan 31 2004, 01:42 PM
If the stock injectors are already at 85% in a stock application why in the world would you try and give the engine more airflow. Anyone know what the duty cycle is for the stock injectors? Why bother with the stock djet? It is not worth it. Go with carbs for the cheap route or run a standalone FI. It is getting cheap enough that you can buy it for about the price of a new set of carbs. The stock cam was meant to give you good torque around town but not meant to have much top end. Porsche would have hated to have a car that was half the price of a 911 outperform it.
seanery
Jan 31 2004, 03:04 PM
If you weren't such a fucking moron we would have let you come back in peace. But no, you're a racist dumbfuck who can't keep his closed-minded mouth shut.
Go play with the nazis and the kkk somewhere else and leave us the fuck alone. We really don't like you here. AT ALL.
You have absolutely nothing positive to contribute. You've been a major pain in the ass since day one.
So, do yourself a favor and LEAVE!
lmcchesney
Jan 31 2004, 04:46 PM
Thanks again Geoff.
I think the main thing is my sons and I can apply the theories we learn.
We reviewed the ruel books again. SCCA seems open for D-jet or other FI. PCA still requires D-jet to stay in the street prepared class. I was hoping to find a tech inspector for both to review and confirm our inturpertion.
When we use a modified cam on the simulator, I can generate a good low end torque by advancement of the cam and also still have good top end (176HP at 5500 - 6000 RPM) with retardation of the cam timing.
I want to get some further advise on split duration cams. Since our discussion on the limitations of D-jet focuses on the overlap, trying to design a cam with near stock overlap, longer intake duration, say 262° and increased exhaust duration for imporved temp control. However, with the increased valve size and porting of the exhaust side, I don't think I need to lengthen the over lap or take away from the power stroke. Besides, all my mixes are with a CR of 8.5-9.0:1.
Brett, having cabs is wonderful if that works for you. My parts do not include carbs. Also, it seems most of the advancements have already been done in carbs. If you look at the responses to our discussions, they seem to be enjoyed. Try one yourself.
Post " Putting Carbs on a 2.2L Type IV. Any suggestions?" See what happens.
L. McChesney and The Guys
DNHunt
Feb 1 2004, 06:51 AM
L
You sure about that flow rate on the 2.0l injectors at WOT. I've never seen anything approaching 50% duty cycle. MS has a display that shows duty cycle as a bar graph and a percentage. Rough calculations show these injectors should be good to about 250 hp (probably a little less since our engines need to run rich for cooling). I feel confident the injectors can handle the job. If Geoff says he can tune the MPS to meter the right amount of fuel I'd bank that.
I would worry about vacuum signature and I'd be concerned about the intake runners and plenum. Someone with more knowledge of intake design may be able to jump in. I know there is some ram effect and that the runner length and diameter, and plenum size affect the rpm band where this aids performance. There are formulas to calculate this (way beyond my knowledge and skill). From what I've read, these can give you a starting place but testing is needed to get something that really works and physical constraints such as engine bay layout tend to compromise the results. The key is you want that effect to fall within the torque band. Significant changes to the internals are going to change this band and whether the stock intake system aids or inhibits the engine's performance then becomes a crap shoot. Obviously, the smaller the change the better chance that you'll benefit from intake tuning inherant in the stock plenum and runners such as it is.
I'm sure there are performance gains from engine design available with FI (stock and aftermarket) but I think it's going to be tough to go much beyond mild cam change, slightly ported heads, better exhaust and recalibrated MPS with D-jet. More is certainly available with aftermarket FI but it looks like a frightening place to me. Looks like a lot of money and lots of risk.
Dave
Brett W
Feb 1 2004, 09:26 AM
Do not rely on Desktop dyno to give you accurate numbers. Unless you are using something like Ricardo Wave 5.0 or Engine Analyzer Pro the numbers you get won't even be meaningful. You can not get 176 HP out of a stock injection based NA combination. The stock plenum cannot flow enough air to support that. If you are running an aftermarket injection using the stock plenum and runners as a you still won't make it. You need to completely redesign the system. With a 2.0-2.2 you will make at most 120 on motor with Djet. I don't care to take the risk of complete motor melt down due to some POS 30+ year old FI failed and melted all the pistons because it went lean at WOT during a track session.
The amount of money that you will put in this engine will be large, why wate the full potential of this motor by trying to run it through a huge restriction. Carbs are the cheapest way to maximise engine potential. The right way to do it is buck up and by the standalone fuel injection and make some real power. Or just be satified with 110hp.
Bleyseng
Feb 1 2004, 09:54 AM
The proven combo with Djet is a 2056cc motor which makes about 115hp or 120 with the Tangerine Header, Webcam 73, portedheads, lots of carefully engine assembly.
I have heard of engines running 100mm p&c's successfully too but those are long gone.
Brad Roberts has built alot of these motors which last on the track or AX course.
The problem is jumping up to a 2270cc motor with Djet, no one that I have heard of (in 10 years) has done it including Jake. I think this is what Brett W is talking about, why beat your head against the wall unless you have lots of money to burn in this experiment. I know lots of people have tried to do this in the past using 103mm pistons and failed.
Hey, if you are gonna try great, I think we will all lend what knowledge and support to try to make this work.
Geoff
Mark Henry
Feb 1 2004, 02:04 PM
QUOTE(DNHunt @ Feb 1 2004, 04:51 AM)
I don't think I've ever seen over 40% duty even at WOT
As far as flow goes I agree with Jake when you hog out the exhaust port you
lose HP. This is true on both the Type 1 and 4. I also have a flow bench and rarely use it. What I do use it for is making sure all my ports flow the same once I've ported a set of heads. I never bother to chart the flows, been there done that in the early 90's.
Guys always get stuck on the numbers...the most HP the biggest flow, it don't mean crap if the engine runs like shit.
Mark Henry
Feb 1 2004, 02:07 PM
QUOTE(Bleyseng @ Feb 1 2004, 07:54 AM)
They didn't use Nickies!
Brett W
Feb 1 2004, 04:11 PM
I am not saying don't try it but I can't understand risking a motor due to archaic fuel control just as a home project. For racing that may be different if there was some money involved. I personally would take the computer and chuck the guts and put a more modern system inside the factory box so that the casual observer would not be the wiser and really make some major horsepower. You are free to do as you choose but I would reccommend against it.
Geoff is right there are a bunch out there that do it with mild 2056s but why bother. Crank it to 2.2 inject it and build a 200hp motor, that will walk all over a 1971-2056. Granted my 2056 did make 140 through stock heat exchangers I really think there can be more. So up to a 2.2 stoker motor with a turbo ought to make things more interesting.
Bleyseng
Feb 1 2004, 09:44 PM
No Mark, it was the fact that they changed the VE curve so much and weren't also able to cool the motor. Maybe with nickies atleast you could keep the motor cool enough to survive long enough you could tune it.
I think Bretts idea is the best, just rip out the ECU internals and hide a MS brain in there!
Geoff
Jake Raby
Feb 2 2004, 12:03 AM
When you use "Cast iron clunkers" (103s that ARE NOT Nickies) you are asking for a failure...
In mY opinion when you ask the stock FI to do anything but a 2056 with a 73 grind, you are asking for it as well.... Thats just me, not being a fan of stock FI at all, in ANY application.
ChrisReale
Feb 2 2004, 12:52 AM
QUOTE(seanery @ Jan 31 2004, 01:04 PM)
I take it a post was deleated by our buddy from the north?
seanery
Feb 2 2004, 07:24 AM
yes.
Brett W
Feb 2 2004, 02:03 PM
What are you talking about? Who got banned?
Mark Henry
Feb 2 2004, 04:26 PM
QUOTE(Brett W @ Feb 2 2004, 12:03 PM)
Alfred.
Canada's only bigot, well besides the OPP.
ChrisFoley
Feb 7 2004, 04:28 PM
QUOTE(lmcchesney @ Jan 31 2004, 05:46 PM)
The cylinder heads (big valves) and displacement you are working with will automatically bump you up to the Modified category in both SCCA and PCA if I am not mistaken.
jdogg
Feb 7 2004, 05:35 PM
Go to :
http://www.moutons.org/sccasolo/Rules/sp.html#s1410 for rules on SCCA CSP. Cams other than stock grind not allowed, and .0472" overbore on cylinders max. Welcome to SSM (SM2).
r_towle
Jan 10 2008, 02:59 PM
I was hunting for this one.
I had this motor and head flow specs.
The motor was 189 hP If I recall.
Carbed.
2.4 liter
12.5:1 CR.
The flow of the heads may add value to the camshaft discussion on a different thread.
Rich
Valy
Sep 27 2011, 10:43 PM
QUOTE(r_towle @ Jan 28 2004, 03:32 PM)
try this
Rich,
Can you help me understand the different rows in this XLS from page 1?
I'm trying to run a simulation of a 2L engine and want to use your CFM for the heads. Should I use the "Corr CFM" at 10PSI?
Anyone else has similar data?
Thanks
