First of all . . .
Looks like you've been lurking about for awhile . . . .
Could be many things. Here's a few to consider: improper timing/valve adjustment, lean fuel mixture, bad fuel, blocked or low air flow (rat's nest in oil cooler ducting/running in too high a gear at low ground speeds), stop and go traffic in the desert in July!, worn main bearings, etc.
You definitely want to make sure the engine is tuned properly and verify the oil pressure and oil temperature numbers . . . .
Many more should be chiming in shortly with possible directions for you to consider.
Good luck,
