75 914 V-8 Project
I don't know if these problems existed before I took the car apart to restore. After putting it back together, I am having two electrical problems...maybe related???
Headlight and Headlight Doors are confused
With the ignition switch on, pull the head light switch to the first position and the dash lights come on. Pull it all the way and the headlight doors open all the way up and then automatically close with the head lights on. If you turn the switch off, the headlights turn off and the headlight doors open backup and stop in the fully open position. It's like it's doing the oposite of what it should be doing.??? I've tried replacing the relays both in the the headlight motors and fuse panel. The wiring all looks correct on the motors.
Brake Light Keeps Flashing on Gauge
Brake light stays flashing with ignition on. The switch under the emergency brake seems to be functioning properly. You have to pull the square relay under the fuse panel to get it to stop flashing. I did replace the brakes (not MC) and there is no reset switch on the MC.
Odd wiring by PO
The emergency stop switch looks like a bus not a 914. Pulling the switch you can see the PO cut a light blue wire at the base of the square relay and ran the wire with a diode directly to the emergency stop switch. No clue what the PO tried or did achieve with this hack.
Looking for help and ideas...
