QUOTE(kconway @ Jul 21 2008, 01:03 AM)
I recently had my heads worked and valves replaced because of damaged valve stems-
Click to view attachmentQuestion is, is it customary to replace the adjusters also?
Kev
Yes, buy a set of 911 adjusters if you can..they are alot nicer to the valve stems.
The old set you have appears to have some hardness issues that may have resulted in the damage to the valve stem...
It could also have been the valve itself that was manufactured poorly.
If you are stuck, show a picture of all of your adjusters with clear focus on the underside that hits the valve stem so we can see if they are the issue.
On the 911 adjusters you need to take a grinder, file, or belt sander and remove about 60 thousanths from the inderside so the adjuster itself can screw up into the rocker arm that 60 thousanths more.
This only pertains to using the 911 swivel foot adjusters and is a simple DIY project.
The need for the clearancing is so that you have enough room to set the rockers correctly.
RIch
