My 75 has the fuel pump in the front trunk with a carb fuel pump ( I think faucet)...anyway, I had placed an adjustable regulator on my carbed V-8 thinking I would need to bump the pressure down. The Eldebrock carb suggests 5lbs of pressure. My pump is only cranking out 2.5 lbs with no regulation. Is that enough pressure or do I need to address the issue? If so, do you think I have a pinched line or just a cheap pump?
Thanks ahead of time...
