QUOTE(6freak @ Jul 22 2008, 10:27 AM)
And you can buy kidney belts at the local Moto`x shop ..you will be piss`n blood after 50 miles
If the vehicle weight goes up but the available suspension travel doesn't, a wheel rate increase is going to be needed to keep things from bottoming, at which point the rate goes infinite, which is bad (like coil bind).
250 lbs/in is jarring on a light car but it's not on a heavy car. I don't know that a 3,3 Subie is 400 lbs heavier than a 2,0 T-IV but I have a 3,0 Subie engine (still happily in service in the Ourback, thank you...) and I can see it being a bunch heavier.
