I have a double wire red w/wht stripe wire to the fuel gauge. I am not getting any power out of it. It should be turn on power but I'm not getting any. Where should I look? The fuses all look good. I assume the wire powers up other things. Help.
904svo
Jul 23 2008, 09:35 PM
Red/White wire starts at fuse #9 then runs to the oil lamp then to the gen lamp then to terminal #15 on gas gauge then to terminal #15 on tach. This is the power feed for the gauges.
Hope this helps you.
ericread
Jul 23 2008, 10:01 PM
From my experience it usually is a bad ground rather than the power feed. Have you downloaded a copy of the wiring schematics?
Hey! Gratuitous Comment!! This is my 1,000th message!!! I have got to get a life
Eric Read
