QUOTE(Elliot Cannon @ Jul 24 2008, 05:10 PM)
I drove a 1967 type I from San Diego to Long Beach California with NO clutch. Start the car in neutral and let it warm up a bit then turn it off. Put the car in first gear, start the engine, (it will bump and buck for a second) and you're on your way. With a little practice you should be OK. Then get the clutch fixed.
Cheers, Elliot
Mine was a '68, same story, different town, Riverside.
My clutch pedal broke Fri. night and I couldn't get it fixed until Mon., no welder, no parts. I still took a girl to the drive-in movies Sat night.
My dad and two of my uncles were truck drivers at different times, they don't use the clutches in those things except for first gear, so I grew up knowing how to drive without the clutch.
Your goal is to match the speeds of the two spinning gears as closely as possible. If there's say 1200 RPM's between gears, you run it up to like 4200 or whatever you'd normally do, lift off of the gas, slide it out of first and when it rev's down to about 3300 or 3200 you start pushing the shifter gently up against the next gear. It will drop into the gear without too much effort when you do it right. Downshifting is harder. You almost have to be good at heel-toe downshifting to make it work, but you can do it. You slow the car down to say 2500 rpm's, slide it out of gear, press the shifter up against the next lower gear and gently speed up the engine until the speed matches what it should be in the next lower gear and gently nudge the shifter into that gear.
I would never call this POWER SHIFTING. This is
eggshell for a shift knob shifting. do it with your fingertips and get really good at it and you can drive everywhere without the clutch except for leaving a stop and you won't damage the transmission. If you drive it like you're POWER SHIFTING you'll ruin $2000.00 worth of parts inside of your tranny in half a day.
I've even finished a practice session at the Streets of Willow with a broken clutch cable. I waited to change it until lunch time.
Eggshells.
