QUOTE(Cap'n Krusty @ Jul 25 2008, 08:39 AM)
Here's a brief rundown of production (AKA, "street") transaxles:
901 (and 902): 1964-1968 911/912, chill cast aluminum case. 1969 911/912, mag alloy case with larger differential. Both 4 and 5 speed versions. First production Porsche transaxle with jointed axles instead of swing axles. 2nd gear fixed on mainshaft.
904: 901 chill cast case, 2nd gear not fixed on the input shaft, ring gear flipped for mid engine use. 5 speed. (Yes, there was a "street" equipped 904 available on order.)
905: 1968-1971 Sportomatic version of the 901, 4 speed
911: 1970 & 1971 911, mag case, pull type clutch. Both 4 and 5 speed versions.
Known to be weak in the area above the front bearing races. 2nd gear fixed on mainshaft.
914: 1970-1976 914, mag case, ring gear on opposite side from others for mid engine use. 5 speed only, gear ratio differences for the 914/6. 2nd gear fixed on mainshaft. Versions to 1972 were "tail shift", 1973-1976 were "side shift", a simpler system with fewer components, and less prone to wear.
915: 1972-1977 911, mag case, several minor variations. Both 4 and 5 speed versions. 1978 and up, aluminum case, internal improvements as time went on.
Final drive ratios varied in production. Later versions had electric speedometer drive components. The 911 Turbo used a reinforced 4 speed version of this transaxle. Factory oil cooling was available.
916: 915 transmission, modified and fitted for mid-engine use in the limited production 916.
923: 1976 912E version of the 915.
925: 1972-1983 Sportomatic version of the 915, 4 speed.
There were various racing versions of all the manual transmissions.
The Cap'n
so a side shift #914.xxx.xxx tranny would be ok in 1970 914-6 ..would it make it better ? or should i just leave it alone..the one in the car is a tail shift...Thanks for all your help
