ok, this bites.
I put the engine back together & reinstalled it. It turned over once and ran for about 6 seconds, then quit. After that, it won't start at all. I can't get it to turn over, so I'm guessing: starter, flywheel/tranny connection or worse. (didn't we just have a post with a similar problem)
I took the starter to FLAPS and it tested on the machine at 50 amps. Is this enought? Haynes says 35-50 no load. I've seen other sources say it should put out up to 110 amps or more.
Before I pull the tranny, does anyone know about the starter specs?
thanks
D
