zonedoubt
Jul 27 2008, 10:35 AM
The voltage regulator on my 1.8L was hooked up this way before (upper left hand corner of photo)...
Click to view attachmentThe engine was carbed and I'm putting the fuel injection back. So obviously I want to put the VR back where it supposed to go on the relay panel.
Anyone comment on why the VR was hooked up that way?
stepuptotheMike
Jul 27 2008, 06:18 PM
Bad relay board maybe? My car is carb'd and the VR is in the normal spot.
-Mike
type47
Jul 27 2008, 06:25 PM
the VR is "backwards", that is, it's 180 degrees reversed. the bottom of the VR and the connectors should be on the board not off as shown. now the reason why the PO did it this way may have been to fix something.
McMark
Jul 27 2008, 09:00 PM
You can wire it that way. The alternator connector usually connects to the relay board. The relay board has internal wiring that connector the three prong plug to the actual VR. It's just a straight passthrough. So if there was a failure in the relay board for those contacts, then this would be a suitable 'fix'.
zonedoubt
Jul 28 2008, 10:50 AM
QUOTE(McMark @ Jul 27 2008, 08:00 PM)
I confirmed that on the electrical schematic in Haynes. Thanks!
