Mueller
Jan 29 2004, 03:22 PM
This is for a pull out knob/switch on the right of the steering column.....it has three wires going to it.
Upon removal of the switch, it started to spark against the dash. How did the body become "hot"
thanks,
Mike
JmuRiz
Jan 29 2004, 03:30 PM
Green pullout knob is typically the rear defroster knob.
Scott Carlberg
Jan 29 2004, 03:32 PM
according to the 914 Tech Tips book that I have, it's for the Defroster.
"Switch configuration on the passenger's side dash face to the Right of the
steering column, left to right, is as following:
Defrost switch (optional), cigar lighter, and on 70-71 models only, wiper switch.
70-72 models used a green foglight switch bezel, while 73-76 used a yellow one".
Jan 29 2004, 03:35 PM
- green knob on pass. side is usually the rear def. switch ...
- green knob on driver side is usually the fog light switch ...
Mueller
Jan 29 2004, 04:26 PM
thanks guys...................
no shop manual here, 3 wires.....two brown (appear to be stock)
one black wire (NOT stock wire or terminal)
anyone trace where the wires go (or supposed to)?
Mueller
Jan 29 2004, 09:18 PM
The car does not have a defrost element on the rear window.....who knows what it is wired to, but it's not done correctly or the switch failed internally causing the hot to ground to the chassis.
