QUOTE(mightydoe @ Jul 29 2008, 08:15 PM)
hey i have some vibraton in the front of my car at around 60ish mph..
i thought maybe new tires/balance would do it.
has anyone had this symptom before?
if that's the problem, that'll fix it.
Also classic symptom of badly-adjusted wheel bearings and worn tie-rod ends. If you have no idea how long it's been on those two items, it's probably time. Check them out and stay safe.
Wheel bearing adjustment is pretty easy and practically free.
Replacing all the suspension parts can get expensive, but sloppy steering isn't safe, so find out exactly what your issue is and get it handled.
There are also ball joints in the picture and early (pre-'72-ish) struts have an unpleasant tendency to wear at the ball joint conection.
Do what needs doing. If everything is worn, you will be amazed at how much better the car handles once it's back the way it left the factory.
