Tinkering on the 1.8 today, found some more vaccum hoses that I need to replace. Looked at the Pelican diagram and....
They show this:
...but what I have is this:
Yes, the decel valve is not hooked to any 5mm hose, just an open nipple.
First question, why is this working?
Second question, if this is working should I change it?
Third question, seems the EGR is no longer hooked to the exhaust, can I run the hoses the way they should be, and then eliminate the EGR by running a hose from the rubber throttle tube to the 710 fill directly?
